how to change dialing numbers
Oct 1, 2007
how to change on-the-fly numbers before i dialing?
example: i call to 0213333333. when i click on "call" this number is changed to 0992133333333.
how to do this? anyone?
obs: i don't speak english! but i tried! :)
Sep 6, 2007
Try this: under "Settings", go to "Phone", at the top is a toggle for "International Assist", turn it off. I do not know if that is the issue you are experiencing, but it seems like it may be.
Oct 1, 2007
app
nope...
i need app to auto change the numbers when i dialing...
the app needs to add more numbers...
ex: i dialing 011 12345678... when i click on dial, the app chage to 011 99 12345678... and dialing...
anyone know if exist any app?
420greg
Jun 26, 2007
845
Orlando, Florida
Changing phone number formating: (123) 456-7890
Formatting is stored in:
/System/Library/Frameworks/AddressBookUI.framework/ABPhoneFormats.plist Download this file from your phone. The file is stored in binary format, so you'll need to convert it to text. Now save this file and open it in a text editor. Change the formatting under us to look like you want (if you find your region in the file, just copy from your region to the us). There's probably some way to just make it use your langauge (instead of 'us'), but i don't know where you specify that. When you are done changing formatting, save the file and upload it to the iPhone in same directory you found it. You don't need to convert i back to binary.
