How to change main menu icon pictures?
roadracer516
Sep 8, 2007
29
I searched and found only one answer and it does not work for me. I want to change out the icons in my main menu (i.e. maps, youtube, weather, notes, etc) Can someone guide me through it using either ibrickr or WIN SCP. Thanks
kwan
Jul 7, 2007
88
You're kidding right?
kwan
Jul 7, 2007
88
OK,
Install the application "Installer" using iBrickr
Then a Installer icon will be on your homescreen.
Use this application to install Summerboard.
Use summerboard to change the "theme" of your homepage.
More summerboard themes are available for download using installer.
Installer is convienient because you can add new apps straight from your phone.
You can also do this by putting summerboard with ibrickr, and installing the summerboard themes with iBrickr.
Do a search for Installer and summerboard for more info on these.
Also try modmyiPhone.com for good resources on modding your iPhone.
Have fun :)
roadracer516
Sep 8, 2007
29
OK,
Have fun :)
Thank you, I appreciate that! I really do not want to change the entire theme. I would rather make my own .png files for each icon and change them individually. I already have installer on my phone as well as Summerboard. I can access all that on WIN SCP but cannot find the acual .png file associated with each menu icon. As you can see, I found the icon .png files for the status bars, carrier logo and WIFI bars and was able to change those pretty easily. Thanks again
