How to Check How Much Data is Used?
Dec 14, 2008
26
Toronto, ON
Can I do this through the iPhone it self or do I have to call my service provider and do some complicating things? lol
jacobjester
Sep 20, 2007
112
Kansas City, MO
I know that you can go to "settings" and then "general" and then "usage" scroll down to the bottom on the screen and it will tell you how much data is sent and received.
If you wait till you get your bill it will get you a detailed account of all data used.
jpm
Aug 5, 2007
212
Or you can just dial *3282# and you will get a text message with the info.
*646# for minutes used/left.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
If you're on AT&T you can also go to the website and check data usage, minutes used as well as messages. I'm not sure how other providers' sites work.
Jul 19, 2008
3,585
40
London or Miami
On the iPhone go to the "Phone" then go to keypad.
Type *646# (*MIN#) to see minutes used, Rollover Min, Unlimited/n&w min.
Type *3282# (*DATA#) to see how much data sent/received...don't bother since its unlimited it wont really tell you.
Type *225# (*BAL#) to see how much you bill/balance will be/is.
To see the data, go to Settings, Usage...then scroll down. Under Cellular Network Data it will show you Sent/Received.
Off topic.... I just checked mine, and in 3 days i sent 54.4MB and Received 2.5GB. LOL!
styfle
Mar 31, 2008
3,381
the data one also shows you your texts remaining
i use that all the time
