how to check what firmware i am running before activation ?
cudo
Sep 27, 2007
hi, just got my iPhone and unlocked it yesterday but im not sure myself how i did it. i installed Installer.app which asked me what firmware i am using but since the process was supposed to bypass the activation i was unable to check what firmware i have but i took the risk and chose 1.0.2 to find out after sucesfull process i am runnin 1.0.0 :)
once i installed installer.app and run activate.bat i bypassed the activation process some how and then using ibricker installed pxl file and the couple of resets :) and then i run installer.app and run anysim :) and my iPhone is ready:)
questions:
can someone put in order the steps to unlock the iPhone safely
how do i chesk the firmware of the iPhone when straight from the box ? and still unactivated ?
if i will update my firmware to 1.0.2 will i have to bypass activation and unlock it agian ?
cudo
neurovurt
Sep 5, 2007
34
not sure about the unlock, but firmware can be found here:
Settings > General > About > Version
cudo
Sep 27, 2007
wish it was that easy , just missing one thing. if the iPhone is no activated you cannot go do settings the check the version. cos all you can do is activate it at this time.
cudo
tesh
Sep 24, 2007
54
**EDIT** just read that you haven't acitivated it? how old is it? im sure you can reference how old your serial # is with others and place yours in what 'stock' firmware it's running
settings > General > about
read Firmware: 1.02 (XXXX)
^ though someone else could enlighten me to the last four digits' meaning
