How to clean a rubber case?
sorbet
Dec 11, 2011
78
14
Ohio
I have an Incipio NGP case that has gotten filthy in the past month or so. It's probably a combination of where I work, plus I constantly shove my phone in my back jean pockets, so the denim dye has transferred to the pink color and makes it look...bruised haha.
Any suggestions on how to clean it? I've tried Dawn with a washcloth and stuff but nothing is working.
Apple iAddicted
Feb 20, 2012
269
27
Could try a peroxide/alcahol solution but it could fade the color of the case too
Sent from my 32GB iPhone 4s on iOS 5.1!
Only thing iPhone is missing is an expandable memory port! Come on Apple give us a microSD port already!
GailLA
Nov 13, 2007
265
35
Northern IL
You might try soaking it in a mild chlorine bleach solution. I usually use a capful of "ultra" bleach to a sink of water -- not very precise, but you get an idea of the proportions. The chlorine bleach should help on the denim blue. I've not done this on my own case because I have no stains, only dirt. For dirt the Dawn with an old toothbrush method works for me. However, if my case were stained, I would try the chlorine bleach myself. Once a case is that stained I don't think you will really make things worse. With a phone case, a thorough rinsing with clear water should be enough to get any residual chlorine off of it when you are done.
yuesir
May 3, 2012
Maybe you should try the rubbing alcohol!
Aaronbrady
May 24, 2012
Yeah its really a painful task i think so.. Anyway you should use warm detergent solution and then scrub with soft brush. And then use warm rubbing alcohol along with the hot. I hope then it will obviously work.
M
miriamshookaf
Guest
You should avoid such covers and use expensive covers. It's like your putting such an expensive thing in a cheaper thing it will harm you!
dorrien12
Oct 13, 2011
65
I bought an expensive case from Case-Mate, it was a light color and it got dirty and nothing cleaned it. I like light colors and wish the materials were cleanable.
sorbet
Dec 11, 2011
78
14
Ohio
I tried the rubbing alcohol, it didn't do much but I appreciate the suggestions!
I have a bunch of other cases, not a big deal
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
My daughter decided to do some drawing on my wife's leather chair today. Searching yielded similar results including hairspray, rubbing alcohol and the magic eraser. All are very good cleaning options, but I was concerned about the impact of the chemicals on the leather. I decided to use Dawn blue liquid soap. They recommend this stuff for travertine tiles, which are also extremely difficult to clean.
In any event, I used a healthy amount of Dawn on a wet paper towel. Using a circular motion, I was able to get most of the pen out of the ivory leather chair.
I know we get more than a few folks viewing this thread and wanted to share this, despite the age of the thread. If it works on leather, I'd certainly give it a whirl on a rubber case.
  • Like
Reactions: Sassytallsista
Tas48
May 25, 2016
After buying a used iPhone 5/5s lifeproof case from goodwill that was insanely dirty and looked very cheap. I used a Baking Soda + Soap + Water solution and dipped my case into the solution. I then proceeded to rub the wet case over with a brush. I repeated that process 4-5 times. Then I got a spoonful of baking soda and placed it on the case and rubbed it with my hands into the dirty areas. I rinsed if off thoroughly and dried it off with a paper towel. The case looks brand new and worth much more than it did on the shelf at goodwill. Hopefully it works for you as well.
