How to clean iPhone back...
srose
Jun 10, 2008
57
Hi
Before I apply the InvisibleShield to the 3G I need to clean the back of it. It has small pieces of dirt and dust on it. How can I remove the dirt and dust without scratching the back?
psylichon
Oct 31, 2007
16,591
751
41
Philly
I would use a lint-free cloth and a small amount of high-% isopropyl alcohol. That should get off just about anything.
srose
Jun 10, 2008
57
Thanks for the quick reply.
So rubbing it with the cloth won't drag the dirt across it causing it to scratch?
Should I use the pre-installation film I got with the anti glare film to take some of the dirt of the back first?
psylichon
Oct 31, 2007
16,591
751
41
Philly
What kind of "dirt" are we talking about? Unless it's bits of metal or glass, you should be fine.
