How to clear pins from map
notlek
Jul 29, 2007
How do you clear the pins off the map after you have looked for a restaurant or gas station etc?
notlek
Jul 29, 2007
That does not work on my phone!
I hae cleared my bookmarks and tried using the gray X on the bottom right side of the screen. Neither worked.
How do I get rid of the pin?
Click in the search bar, and click the gray X on the right hand side.
Napoleon PhoneApart
Jun 19, 2007
33,493
4,417
Upper Marlboro, MD
You need to hit "x" in the search bar, which is the box that you type your locations into.
Coincidentally, I was wondering the very same thing just a few minutes ago...
