How to copy contacts from Outlook to iPhone
rahullsud
Dec 9, 2007
I am unable to copy contacts from outlook to my iPhone please advise?
termleech
Sep 7, 2007
1,154
McPherson, KS
In iTunes did you make sure to tick the box that says sync contacts with this computer? If not, it won't sync.
rahullsud
Dec 9, 2007
thanks it works
it works thanks and how do we load softwares on the ipod i have a unlocked version for my iPhone
termleech
Sep 7, 2007
1,154
McPherson, KS
You said you unlocked your phone, have you also jailbroken it? They are two separate things that some people often get confused.
What version of the firmware are you running? If it's 1.1.1, visit jailbreakme.com and it will do everything for you. Then you can use Installer to install third party apps.
Sep 30, 2008
Hi where do i find the box that says sync contacts with this computer? Please advice. Thanks
fabermi
Dec 11, 2008
Microsoft Exchange on my HP
Is there any way I can load my 2000 contacts from my HP in Microsoftr Exchange onto my iPhone?
pthomas
Jan 3, 2013
Install iTunes in your PC and connect the iPhone, then select the mode in the iPhone.
Open the iTunes application your iPhone will show in that application it means you have successfuly connected drag and drop the songs from my computer to iTunes application it will transfer.
