How to delete winterboard items.
Dec 21, 2008
21
34
NY
So I've had my iPhone a few days and I've gone a little overboard with downloading from cydia. There's quite a few things I don't want anymore, is there a way to remove them?
Also, I see the "thanked" under peoples names, are those thanks from other users? If I could thank the people that have helped me so far I'd love to, but I haven't been able to find anything about that :p
You can remove them through Cydia by going into the "Manage" section at the bottom of the app and then tapping "Packages' and finding the theme you want to remove. Select it, tap "Modify" in the top right corner, then "Remove". Or, if you have SSH set up, you can remove them by deleting them from /Library/Themes.
Thanks buttons will show up on everybody's posts once you have reached 25 posts. This is simply a spam protection measure we have set up. Welcome to the site!
Dec 21, 2008
21
34
NY
I completely missed that option. I appreciate the help, thank you ;)
28,365
5,507
"Or, if you have SSH set up, you can remove them by deleting them from /Library/Themes."
I'm using iPhoneBrowser to manage themes etc. Is it technically SSH?
Does anyone have directions on how to use Cyberduck as an iPhone browser?
