How To Enable 3D Maps on Older iOS 6 Devices
iphonewarrior
13,847
699
iOS 6's 3D Maps for some reason aren't compatible with the iPhone 3Gs, iPhone 4 and iPod Touch 4th Gen.
The iPhone Dev-Team released a bespoke version of Redsn0w; 0.9.13dev1 - This enables the user/jailbreaker to use SSH on their device. Redsn0w can be downloaded here for Mac and here for Windows.
Once you've jailbroken iOS 6 you will need to download the debian file (.deb) and install it onto your device via SSH. Navigate here (this is the main site) or download the .deb directly here (dropbox link).
Launch a Terminal type app on your device or simply use the Terminal interface through SSH (should be built into your client). Type the following: apt-get update
...next you will need to type: apt-get install mobilesubstrate
Using your SSH still, copy and paste/drag and drop your newly downloaded .deb file to /var/mobile
and type the following to complete:
cd /var/mobile
dpkg -i com.alpden.3denabler_1.0_iPhoneos-arm.deb
You should now reboot your device and enjoy 3D Map goodness.
fijiman
Feb 13, 2011
832
64
UK
The jailbreak is primarily for jailbreak devs.... had a quick look around ios6 file structure...still looks the same-ish...good for people who like to theme.... Can't wait for full release of IOS6.0 plus Untethered jailbreak....
iphonewarrior
13,847
699
Hopefully we won't have to wait as long this time.
