How to enable tethering in iPhone OS 3.0
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Not sure about the PC side of things, but these directions (via Crunchgear) enabled tethering for me in less than 5 minutes. Today really did shape up to be a good day.:cool:
styfle
Mar 31, 2008
3,381
Nice, I cant try it now but it looks like you just use terminal to change the settings in iTunes to allow carrier updates again lol.
15,384
1,089
couple of notes:
- type that command in ONE line. The way it's formatted there, it kinda looks like there's a line break.
- if you have iTunes open when you run the terminal command, you must restart iTunes for it to take effect.
15,384
1,089
anyway, it doesn't seem to be working for me.
is it supposed to work with V1s?
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
you shouldn't need netshare, right? the functionality is built into the OS now.
Well I say that in anticipation of some sort of carrier update that could get around the "fix". Wouldn't it be great if AT&T enabled MMS but in the same carrier update they disabled tethering (if that's even possible of course).
iStealth
Nov 5, 2007
421
You my friend are the Man! Thank you!:cool:
zandrik
Jul 27, 2007
175
Awesome!
I was trying to figure this out last night. This time it worked! Awesome!
Much thanks!
Joon
Jul 14, 2007
214
All of you who now have tethering unlocked, will notice that your visual voice mail does not work anymore. You either get tethering or visual voice mail. I don't recommend doing this trick to unlock tethering. That is just me though.
hotskate
Sep 21, 2007
314
33
when i try and click the ipcc file it doesn't work
15,384
1,089
if iTunes was open while you ran the terminal command, quit and restart iTunes.
15,384
1,089
ok, sounds like you're typing those terminal lines in two lines. type it ALL in one line (ie no enter after the "com.apple.iTunes").
if the command runs properly, you will get no output in terminal. just a new line.
hotskate
Sep 21, 2007
314
33
defaults write com.apple.iTunes carrier-testing -bool TRUE
hotskate
Sep 21, 2007
314
33
got it thanks a bunch... anything on MMS?
zandrik
Jul 27, 2007
175
hmmm my visual voicemail works fine. even after unlocking the tethering.
