How To Fix Apps That Crash After Installation
Techno_man
Oct 27, 2007
56
This Is How To Fix Apps That Crash After Installation
Go to Installer.app then hit the Productivity folder Install the file manager "Squid"
Go to your SpringBoard and open Squid
Go to the Applications folder
Choose the applications that is needed to be fixed, in my case it was CallD
Open the file that is named after the application (it is the name of the applications most of the time)
Then, Lastly, make sure that your green boxes are checked the same way mine are checked and then click Apply.
