How to force restore
crazyone
Jun 12, 2012
Ok so after an hour on the phone with Apple and having to retry all the basics like soft reset, hard reset nothing worked. So here is the way to force a hard reset (this will erase all data so hopefully you have backed up!)
I used this when my iPhone 3G was stuck on the Apple logo and would not do anything else. Even after a hard reset (Holding down the home button and power button for 10 seconds). iTunes would also not recognize my iPhone when plugged in.
I am NOT responsible for anyone doing this. I did this myself and it worked fine.
1. Hold down the home button and power button at the same time. This will force the screen to fade and the Apple Logo to reappear. KEEP holding the two buttons down until the iPhone shuts off.
2. Once the iPhone is off plug one end of the usb cable into the PC .
3. Open iTune
3. While holding down the Home button plug the cable into the iPhone.
Contunue holding the home button until the you the iTunes logo and the picture of the cable on the iPhone screen. This may take up to 30 seconds.
4. Voila iTunes should now detect the iPhone and you can perform a restore.
Hope this helps someone. Maybe stickie this?
Cheers
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
This should put your iPhone into a Recovery Mode when iTunes does not fully recognize the iPhone. You can then perform a full restore and then set up as new or use a previous backup.
Thanks for your post. Glad it helped you. :)
