how to get to 1.1.1
tizzle
Oct 20, 2007
46
quick question, I have a jailbroken 1.0.2 i want to upgrade it now. but how do i get 1.1.1? thanks in advance
kariya9mdoa
Oct 26, 2007
80
upgrade
ok first you need iTunes and the you need 1.1.1.ispw from modmyifone or Apple and then when you have that open iTunes wait for it to pick up your iPhone then on a mac hold down the option key and click update navigate to where you downloaded you 1.1.1 file and open it and that will upgrade your iPhone and shift i think on a pc. after that you should be at the activation screen now go to modmyifone again go here http://www.modmyi.com/wiki/index.php/Jailbreak_the_iphone_1.1.1_out_of_the_box and this will get you jailbroken and then go here http://modmyifone.com/wiki/index.php/Unlock_the_iphone_1.1.1_out_of_the_box and for these jailbreak and unlocks you don't need a computer it is all done on the iPhone. now you should be unlocked on 1.1.1.
HappyModding
tizzle
Oct 20, 2007
46
thanks a bunch, i was able to get the upgrade files. Now I'm unlocked and jailbroke at 1.1.3. Thanks for your reply.
