How to have update on Installer disappear
miketl
Oct 23, 2007
104
hello all,
well as you all know on the installer there is an update called 1.1.3 openSSH fix. it allows reinstall of openssh after soft upgrading 1.1.3.
I myself is still on 1.1.2, so i wont be needing to update my openssh. the annoying this is everytime i go into installer it shows 1 update and on the installer icon is have a little 1 showing there is 1 update. how do we remove this from the update section without downloading it.
thanks in advance
cybergreg
Jul 21, 2007
26
edit and remove the entry in /var/root/Library/Installer/LocalPackages.plist
This will make Installer think you do not have OpenSSH install, as such no upgrade
miketl
Oct 23, 2007
104
will i be able to still use my SSH?
