How to install a screen protector perfectly?
IllusionEntity
Jun 3, 2010
1,987
163
Borough Green, Kent, UK
Ok this is really irritating me now. I try to install protectors on my 4S and I make sure the screen is 110% clear of lint, dust and crap.
AS SOON AS I lay that protector on there is crap all between the protector and the screen!? How the hell can I install without this problem. I will soon leave the shields as they have to be physically invisible for them not to annoy me or make the phone look pants.
fury
Oct 23, 2007
2,274
236
34
Louisville, KY
I'm not even going to touch that... (oh, I guess I just did)
Try in the bathroom after a nice hot steamy shower. The humidity tends to keep the dust under control.
patrickj
Sep 2, 2007
6,221
407
Austin, Tx
ipadinsight.com
I'm epically terrible at doing these installs, and always prefer to have them done for me when possible. I do know one tip that works well for most people though:
Do your install in the bathroom. Run the shower with steaming hot water. Keep the door shut and let the room get steamy. Clean your screen and you should find that the moisture in the air helps to keep dust and gunk off the screen during the install.
besweeet
Jun 7, 2009
968
26
San Antonio, TX
briansweet.me
I've been installing screen protectors perfectly, even on my iPad. The secret? Scotch tape. You're guaranteed to get debris between your screen and the film, so keep some scotch tape handy so that you can safely lift a part of the film up and grab the piece of dust (or whatever). Works perfectly.
For me, it takes quite a while to do, usually 30-45 minutes, so take your time.
Also, never use the screen protectors that use liquids. They have horrible quality afterwards and are usually kind of mushy.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Everytime I do mine i become this paranoid schizophrenic maniac who's about to burst a vain. I hear people talking to me and when I see the dust underneath anyway I cry.
Tell me if that works, I need to install mine soon.
VOLS34
Jun 25, 2010
1,119
79
Get a Moshi. Just line it up & press it on. Don't have to worry about the bubbles & crap. Comes with a small microfiber cloth to get the screen all nice & clean. Just be quick once you peel it. Well it doesn't matter because it's removable & reusable.
Dj101
Nov 21, 2010
114
Pensacola Fl U.S.A.
www.Mix.dj
i always do mine the zagg way....wet...i use alcahol in a small spray bottle and a small squeege to get it out from under.
the wet way will give you a chance to center it perfectly before removing the underlying alcahol
and the faster the better....it takes me a total of 2min,at most,to do one properly
IllusionEntity
Jun 3, 2010
1,987
163
Had Zagg on my 3GS and 4 for a while. Great protection... But they suck IMO
VOLS34
Jun 25, 2010
1,119
79
Took me about 30 seconds if that. No water, no alcohol, no squeegee.
IllusionEntity
Jun 3, 2010
1,987
163
Just improvised and I got both on perfect. And I mean perfect. Lay your device on a flat surface. Then lay a hair dryer on that side. Point it towards the iPhone on the lowest heat setting. Now clean the screen. Keep checking to make sure all the crud is off of the screen. The hair dryer will not get the crud off of the screen. But it will keep it off of the screen during installation ;)
