How to install emulators on iPhone?
nirav464
Dec 24, 2007
81
can someone post a complete guide on how to install emulators on the iPhone?
RichR
Sep 30, 2007
181
Is there a better way to get the PSX ROM's into the iPhone with a windows PC? The ROM's are too big to send through sendspace which was the easy way to do it and how I have been doing it for some time now.
EDIT: Ok, using winSCP and following the instruction with the IP address and user login which is root, but it asks to put in a password and the instructions say use: dottie as the password. Well, when I try to login it says invalid password to the "root" login. What am I doing wrong?
EDIT#2: NEW PASSWORD WITH 1.1.1... ALPINE.. DUHH, SORRY ABOUT THAT.
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
Try "alpine" for the password. If that doesn't work search for a program called iPhoneBrowser. It runs on Windows and doesn't need a login to access your phones files.
