how to know if your iPhone is unlocked jailbrocken?
NickT916
Jan 4, 2008
266
i have ATT but the phone i bought the guy said its jail brocken and unlocked, how can i check that its both? thx
Jul 6, 2007
1,832
26
Marietta, GA
about.me
Well if it is jailbroken it will have cydia and/or installer on it. If it is unlocked, I have no idea how tell if it is. Why do you need to know? If you have AT&T then it shouldn't matter, unless you are not eligible to change your plan to an iPhone plan....
Cusca
Apr 27, 2008
320
ROMANIA
www.cusca.3dk.org
if it unlocked it will work with all carriers you should try using a sim from another carrier, if it works it`s unlocked
NickT916
Jan 4, 2008
266
ok awesome, so unlocked = i can use other carriers and jailbrocken = i have installer?
person who sold me had Tmobile and it has installer so i think im good to go :) thx!
