How to load contact list from SIM card
Status
Not open for further replies.
datasunny
Sep 5, 2007
hi all,
Im putting my existing sim card to iPhone, but no contact in sim card shows on iPhone. How can load/copy contact list in sim card to iPhone and use it?
thanks
datasunny
Sep 5, 2007
The sim card does not load any contact info, it is all stored in the iPhones flash memory. All you can do is load it from your computer by doing a sync.
thanks for the quick reply.
i stored my all contact info to my sim card using my old cell phone.
what's why i want to load/copy contact list from sim card to iPhone.
iv done that before using a sony ericssion phone
WHODAT
Sep 6, 2007
You cannot do this like you did on your Sony. The only way is to get software to sync your existing contacts to Outlook or some other program, and then sync your iPhone.
KTran
Sep 12, 2007
37
TX
i called into cingular now AT&T about that.
rep tells me that contacts on sim will not load up. you will have to manually input contacts on iPhone. or , as stated previously , sync by outlook or address book .
i had to enter nearly a hundred contacts, i left some out because well they are not needed. :p
hope that helps,
KT
250967
Jun 4, 2008
hi all,
thanks
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
hi all,
thanks
You can't. iPhone will only read the contacts from your Outlook or Windows Mail accounts if you're on a PC and Mac Mail if you're on a Mac. The only other way to add contacts is by keying them individually.
adseguy
401
hi all,
thanks
Nice n00b post, you at least went about seraching, yet you still post the exact same question that has been answered.....:mad:
psylichon
Oct 31, 2007
16,591
751
40
Philly
There is a program on installer (if you're jailbroken) called iSIM that will supposedly import/export from/to your SIM card. I haven't tried it.
250967
Jun 4, 2008
Thanks for the prompt reply.
I've heard that there is way through a software?
Please advise
Marianne
2,326
29
Massachusetts
marianneschultz.com
hello
trying to find this software ISIM to loadmy contact list from sim card
Cant find it, Any ideas?
as psylichon stated, you must have a jailbroken iPhone. is your jailbroken (do you have an application called "installer" on your home screen)? if not, this software will not help you and there is no other way to load the contacts from your SIM card onto your iPhone directly.
Saverino
Jun 1, 2008
4,480
92
Burbank
I remember seeing a screenshot a while back of software 2.0 showing an option saying something like, "Copy Contacts from SIM Card"
So the next iPhone/Update will be able to. I think..
ibeluke
Feb 2, 2009
Load sim contacts, piece of piss
On my iPhone 3g should work on all iPhone
Goto Settings,Mail contacts etc, load sim contacts, done
Way too easy
josmi
Jan 6, 2009
69
What the? I'm able to import SIM contacts and have done so several times!
Hit Settings>Mail, Contacts, and Calenders>Scroll down a bit and hit Import Sim Contacts
This will not show up unless you have the sim card in. o_0
I have tested it out with T-Mobile sim cards.
EDIT: Sorry, ibeluke, didn't see your post. I get too lazy to scroll down on my iPhone sometimes. hehe.
Status
