How to load wallpapers on iPhone?
Retromoe
Apr 9, 2008
73
Queens,Ny
anyone know a simple quick way to load wallpapers on the iPhone?
and why is it that some summerboard themes never work on the iPhone? only a few work but the other themes would just use the standard wallpaper that's used on the lock screen.
Wallpapers are located in /Library/Wallpaper - you can drop them in there through SSH providing they're .png files.
- John
Retromoe
Apr 9, 2008
73
Queens,Ny
Edit: Nvm
thanks a lot!
any solution to - and why is it that some summerboard themes never work on the iPhone? only a few work but the other themes would just use the standard wallpaper that's used on the lock screen.
Check to make sure you have 'Theme Wallpaper' turned on in SMBPrefs and install the theme fix from Installer. Also, the theme might not include wallpapers.
- John
Retromoe
Apr 9, 2008
73
Queens,Ny
thanks for the tip, i noticed it didn't have no wallpaper but a different dock setup. thankss
