How to make your own ringtones, like in iTunes
ciaran00
Jul 21, 2007
242
Is there an app out there that will let me pick a sample window of an mp3 and then add fade-in and fade-out like iTunes does? Can we use that iTunes functionality on our own ringtones?
Thx!
arothman
Jul 28, 2007
74
You can use Audacity, which is a free audio editor, to do that. You can't put the edited version on the iPhone as a ringtone though, unless you're not planning to update your phone. Newer versions of the firmware don't allow you to put rings on there without choosing from the limited selection in the iTunes store and paying $2 each.
mrgisriel
Sep 24, 2007
57
If you already upgraded to 1.1.1 then no, if not you can use iPhoneringtonemaker works great and dosnt hack your phone.
Hope this helps
Derek Gisriel
