How to play real audio files on iPhone?
dinosaur1
Nov 10, 2007
516
I have a number of Real Audio files on my PC. Is it possible to play these on the iPhone? Would I need to convert them? If so, any suggestions on what software to use and what file format I should convert them to for optimal playback on the iPhone?
Sep 29, 2007
348
I am not sure how you can play it on the iPhone, but you can try this. Its free and it converts real audio files to mp3 so you can play it on the iPhone.
http://www.rm-mp3.org/
coolie
Sep 18, 2007
131
No, It's not possble. You can always click and drag it to iTunes and it might convert it for you.
420greg
Jun 26, 2007
845
Orlando, Florida
If it is a real audio stream then you can paste the stream URL in to orb then access orb from your iPhone. Orb will see you are using mobile safari and convert the stream to QT format.
dinosaur1
Nov 10, 2007
516
i go to a website and go to a drop down box where the real audio file exists. how do i put into orb if i cannot copy and paste?
coolie
Sep 18, 2007
131
There are not that many real audio file on the net, so just convert it or find the mp3 version.
dinosaur1
Nov 10, 2007
516
when yu say convert it you mean convert it on my computer and then put it in myiPhone's ipod correct?
