How to put an audiobook on an iPod?
frizz
Mar 25, 2008
91
61
Philly
can someone tell me the process of putting an audiobook onto an ipod
1,747
52
Long Island N.Y.
If the audiobook is on disc, then you put the disc in your computer and open iTunes, the click the import button on the bottom right and it will put the book into your library, do that for each disc you have, than connect your ipod and click sync, if its from audible.com it will go directly into your iTunes library if you installed the audible download manager.
frizz
Mar 25, 2008
91
61
Philly
where do you find the d/l manager?
