How To Reinstall Terminal.app?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
So I'm still pretty much a Mac newbie. Got instructions from a software publisher that require entering a command in Terminal to fix an issue etc.
I just discovered terminal.app is not in /Applications/ Utilities. It does not show up anywhere if I search for it in Spotlight and Quicksilver. I'm logged in as an admin level user, so assume search should see / show all files. No idea why it's missing.
Anyway, I'm looking for the easiest way to reinstall it - I had initially assumed I might just find it on one of the Leopard install discs, but just read an Apple support forum thread that talked about /Applications folder being hidden on there etc.
Any suggestions for best way to reinstall / where to get terminal.app from would be mucho, mucho appreciated ...
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Blah - thought I had it sussed - DLed an app called Pacifist which let me look inside packages etc. on the Install discs. Found the /Applications folder under one of the Essentials packages, found Terminal.app, chose to 'install to default location' and cool, it put it into my /Applications/Utilities directory on the HD. But when I go to launch it I get this:
I guess my reaction now is WTF ? This is on a MacBook running Leopard 10.5.5 btw.
15,384
1,089
weird.
i'd try doing it myself, but my disc drive is busy at the moment...
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Thanks Hippo - have been on Apple discussion forums now too - found a lot of similar issues with 'missing' utils after an update or reinstall. Have seen a few suggestions about running 'combo updaters', but none with a 'hey that worked and we're back in Kansas now' type happy ending - and I have no clue how to run one of these as yet.
Computers = huge fun :)
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
found this thread that might shed some light on the situation...
http://discussions.apple.com/thread.jspa?threadID=1396002&tstart=45
Thanks again - saw that one earlier too. Only thing is, that guy talks about going to a second Mac and running some command-line stuff to see the /Applications folder etc. I don't have a second Mac around, and I've been able to see / extract from that folder - just cannot get it to launch now. Or maybe I missed something in there - I'm tired, so very possible ...
15,384
1,089
no...
got a linux computer?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Think I might have found what I need. Guy on Apple discussions said I needed to install this after the reinstall of Terminal:
http://support.apple.com/downloads/Mac_OS_X_10-5-6_Combo_Update
I had mentioned to him twice that I'm not at 10.5.6 yet, so was he sure about the recommend - met with silence. So went to that downloads section and searched for same file name, except with 10.5.5 swapped in and DLed that, as that's my OS version right now.
Gonna try it in the morning as whenever I try one last thing late & tired, it ends up kicking my ass :)
15,384
1,089
gotcha. good luck.
why haven't you updated to 10.5.6?
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
Let me know if you got it working. If not, I'll see what I can dig up tomorrow (Saturday)
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
So this morning I verified with guys on Apple discussion forums that it was cool to run the 10.5.5 combo updater thingie. Ran it successfuly, restarted the Mac as required, and launched Terminal, or tried to anyway. This time no error message, no indication at all as to why it won't run, just no response.
My newbie guess on this is that it's maybe a permissions issue - but at this point to be honest, frack it - it strikes me that the 'it just works' Leopard OS should maybe sort its permissions out for itself via that updater package, or make it less than challenging to reinstall a single standard system utility.
So I downloaded the iTerm app - and ran my one simple command needed to fix a single issue in a single app.
Blah - I love my Mac, but there are occasional times where it seems to me the simplest of issues requires trekking up a mountainside and seeking out a freakin shamen to get answers ...
15,384
1,089
have you tried to verify/repair the permissions on the disk with Disk Utility?
15,384
1,089
yeah, just search for "disk utility" in spotlight, highlight your "mac" partition, and click "repair disk permissions".
than grab a sandwhich.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
I'm such a lazy twat. I've used iTerm when needed (very rarely) and still haven't got round to running that util to correct all permissions ...
Edit: Interesting that you cannot get Alfred Hitch****'s full name in, but twat gets past. I may refer to Al as Alfred Hitchtwat from now on :)
