How to remove the SIM card
martigen
Jun 30, 2007
14
It's been said in previous topics that the SIM card can be removed, can someone post a step by step guide of how to remove the SIM card.
MoJoe
Jun 28, 2007
94
www.joebeleznay.com
It's very easy, you see the slot on the top of the iPhone, next to the earphone jack. You'll notice a little hole there, use a paper clip and push it into the hole. The sim card tray will pop up and you just pull it out and will be able to pop the sim card out of the tray.
Joe
