How to reset or enter DFU mode on iPhone 7, 7 Plus
Indabaa
Sep 9, 2016
First of Install Latest iTunes Version in you Computer
Step #1. Connect your iPhone 7 to your computer.
Step #2. Switch off your iPhone 7 or 7 Plus.
Step #3. Press and hold down the On/Off button on the right side of your iPhone for 3 seconds.
Step #4. Press and hold down the volume down button located on the left side of your smartphone while still holding down the On/Off button.
Step #5. Keep holding both buttons for about 10 seconds.
(If Apple logo appears on the screen you have held them for a bit too long. Then, you need to start it again.)
Step #6. Next, you need to let go off the On/Off Button. However, keep holding the volume down button for about 5 seconds.
(If you hold them for a bit long, “Plug into iTunes” will appear on the screen. Then you have to start it again.)
Step #7. Now Your iPhone will now enter into DFU mode. An alert from iTunes wil appear on the screen; saying it has detected your device and will allow the phone to be restored.
