How to restore from backup?
jwp
May 9, 2009
53
This may have been asked many times, but how do I restore my iPhone 3g from the "backup"? Everytime I sync, it says its "backing up my iPhone". Where is this backup file?
When I first attmepted to update to OS 3.0, I got some kind of error message and it locked up my phone (non-jailbroke). I ended up telling it to "restore". Unfortunately, it restored it back to the factory config. Lost all my contacts, photos, calendar entries, etc... Finally got the OS 3 update in and the next time I synced it replaced most of my contacts. Some contacts were still gone and all my pictures and calendar entries were still gone.
So...sorry for the long story.....how does one just take your phone back to its last backup point?
jdinner
Dec 14, 2008
47
With your phone connected in iTunes, right click the phone in "devices" on the left column and choose, 'restore from backup'
jwp
May 9, 2009
53
Wow, now thats simple. You would think that would be one of the "options" they would give you when you first connect. Thanks!
Cobra302
Jun 15, 2009
i actually just got off the phone with Apple support where they told me the same thing. lol, i should have come here first.
RedStripe
Jun 25, 2009
When you Restore from Backup, what does and does not get restored? I've heard apps don't get restored, is that correct?
I'm not talking about syncing apps. For example, if I've never used iTunes to sync my iPhone since the first day I activated it (except to do a backup), and have since downloaded 100+ apps directly on the iPhone through the App Store app, but never used the "Transfer purchases" to sync my iPhone apps to iTunes, will I lose all my apps when I do a Restore from Backup?
Zanthe
#apple
Aug 9, 2007
2,638
323
I've never really had occasion or need to restore my phone but have been thinking of doingReally starting to bother me when at times when I tap the end call button the phone just freezes. Been happening more and more.
When I hook up to iTunes there is the button to restore to factory settings. But I want to restore from backup, right? Don't see that as an option.
Can somebody tell me how to do this?
Kriss
Jun 8, 2008
598
121
43
Cape Cod
voyager01.deviantart.com
When in iTunes, look for your phone to be connected, upper right corner for me.. Click on the device, then click on the Summary tab. The second block of info will have manually back up and restore. Just pick the restore from the list that pops up. That should do it.
Kriss
Jun 8, 2008
598
121
43
Cape Cod
Also..If those aren't showing up for you, try plugging your phone into your USB port.
5,580
Hit the restore button. When it's done restoring the firmware it will ask if you want to set it up as a new device or use your most recent backup.
Ms Cola
Sep 18, 2007
116
www.marykay.com
Don't forget to backup first before you restore the phone. iTunes should ask you if it doesn't have a resent backup.
Sent using iCafe app
Zanthe
#apple
Aug 9, 2007
2,638
323
That's the missing step I didn't know about...thanks everybody!
So is it a good idea to restore and maybe it will settle this phone down?
5,580
If a hard reset didn't fix it, a restore is the next step.
Zanthe
#apple
Aug 9, 2007
2,638
323
OK...reluctantly I am going to do it. I've done lots of hard resets but clearly it's not fixing anything. But I am going to upgrade from 6.0 first. lol
5,580
You don't need to upgrade and then restore; you can just restore to 6.0.2.
