Solution for saving pictures.
i got an MMS.
iPhone says "go to www.viewmymessage.com, type in ID XXX, and password XXX".
I see beautiful pic and want to save it to my computer.
but no right clicking to "Save as" or even copy.
it just gives me Loop, Rewind, Play, or FFWD.
But it's not a video, it's a pic.
how to save? help!
There is no way to save that image off of the iPhone itself.
Like the other guy said, you could go to
www.viewmyimage.com on your pc/mac and take a screen shot and crop it out in paint.
The only way to be able to go to
www.viewmymessage.com ON YOUR iPhone and save it from there is to Jailbreak your iPhone.
http://[URL="http://www.ZiPhone.com"]www.ZiPhone.com[/URL] is the website you want to go to to jailbreak it.
After you jailbreak your iPhone you will see a new icon, Installer, click on it and go to install. Then, all packages. Then look for a package called "IMGsaver". This allows you to save pictures on the internet (
www.viewmymessage.com). You also need to download a package called "Safari add-on features". It may not allow you to download IMGsaver without it so you might want to download that first.
YOU MAY need to download a package called "jiggy runtime". Most packages require it but i'm not sure if these do. If they do require it, don't worry, there will be a message that pops up and says so.
The instructions on how to work this App will be in the App itself. It seems pretty self explainitory to me but if you have any questions just email me.
After you have the picture saved onto your iPhone, you can simply email it to yourself. Then all you have to do is get on your email on your home pc/mac and save it from there.
IF YOU DO NOT SEE THOSE PACKAGES IN ALL PACKAGES. IT MEANS YOU HAVE TO GET ALL SOURCES.
So do this:
Go to the new installer App on your iPhone and go to sources. (bottom right)
Then, go to edit in the top right corner then add in the top left corner.
Next, type in this:
http://ride4.org/shai.xml
Then click ok and let your sources refresh.
Next, go to the install button (bottom left) and go down to the category "sources". download the package that says "All sources".
This will unlock every source for your iPhone. Which will include the two packages you need that I named above.
I really help this guide helps. Post back if needed.
