How to shut off Edge while using wi-fi
guest0320
Nov 11, 2007
728
Is it possible to shut off Edge?
I was in a Wi-fi hotspot today. Complete signal, all bars lit and I kept going from wi-fi to E to wi-fi to E and got NOTHING accomplished.
I know you can shut off wi-fi, can you shut off that lousy Edge?
Dana
6,682
It shouldn't be hopping back and forth. The only reason that the WiFi should get interrupted, is if you are receiving text or calls during that time. Did you have any new text or voicemail at any point during trying to get connected?
Doby45
Aug 21, 2007
543
Powder Springs, GA
I agree with leech, this is not an issue with your phone, but an issue with the HotSpot. If it loses the wifi signall it will bounce back to Edge. Not the other way around..
smokepsp32
Dec 2, 2007
45
I installed NetServices via installer and it works fine, i can turn off the edge...
the only thing is, it still appears beside the carrier logo...
termleech
Sep 7, 2007
1,154
McPherson, KS
I'm not sure how NetServices works, but if it's like iToggle, it doesn't really turn off the Edge. What it does instead is put an invalid IP address on the Edge interface which will cause your phone not to us the Edge connection. It doesn't really turn it off, just causes the phone not to use it.
Tinman
4,334
183
Aridzona
I agree that this is most likely a WiFi issue (one of my routers used to do exactly that).
That said if you really want to kill EDGE you can pop the SIM card out (don't need to remove it all of the way, just a nudge so it loses contact).
Unfortunately if you do disable EDGE it will probably just drop the WiFi connection entirely, instead of switching to EDGE (i.e., you still won't be able to get anything done).
So in the end it might be better to switch off WiFi and let EDGE do its thing. At least you'll be able to actually hold the connection.
Mike
Chris716
Nov 29, 2007
807
IL
sounds like your place you were at was having some wifi issues being that ive never had that happen to me and E would only come on if wifi went down or something
