How to sync photos to iPhone
Brandon!
Jul 4, 2007
34
I haven't been able to get any of my photos (all in .JPG format) to sync with my iPhone. When I go to iTunes (Windows) and I tell it which directories to sync, they never appear in my iPhone Photos. If I watch the status in iTunes, it says optimizing photos... syncing photos... but nothing seems to get uploaded. I used to get a popup that said "XX photos couldn't be uploaded", but I don't get that anymore (not sure if I accidentally hit "don't show me this again").
Is there something special I have to do to my photos? I did try resizing them to 1600x1200@72dpi like the iPhone takes, but that didn't do anything for me!
hiphop101
Jul 28, 2007
40
You'll have to turn off your firewall in preference...if youre using a mac
Brandon!
Jul 4, 2007
34
Sorry, I'm using a PC (Windows Vista even). I also have the latest iTunes version installed.
Any other ideas?
marilynrocks
Dec 8, 2009
I have synced a few photos on my iPhone and it went well. I selected the proper folder and what not. Now that I go to view my newly added photos it shows up as two separate folders with the same exact photos. One is the the folder that i wanted to sync to the iPhone and the other looks like a new album that the phone creates called photo library. Is there any way I can sync folders without having multiples of them?
dturner
Dec 15, 2007
5,725
Louisville, Ky.
This is the way the phone works. You can create as many folders as you want, but the same pics will be in the photo library.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
Your welcome. Not sure of the reasoning behind double pics, but that's just the way it is.
BTW: Welcome to EIC. Don't be a stranger.
marilynrocks
Dec 8, 2009
Why thank you! Very nice of you! I see under your profile you can "thank" someone. Since I'm only a couple hours new to this why not I ask you! So how do you go about doing that?
iNinja
Aug 8, 2008
3,985
20
UK
When you have over (I think ) 10 posts, you will see a thanks button under peoples posts. You just click that and they get thanks! :)
Welcome to EIC
isaingj
Dec 4, 2011
61
I have a large library of photos on my PC. There are some photos that I would like to carry with my on my iPhone. How do i sync photos from my PC to my iPhone 4S?
manamaboy
Nov 24, 2008
On a PC, the sync will be done between a folder(s) and the photos app in iPhone.
Remember that pics residing the camera roll, is NOT synced in this process. You have to manually copy paste into your PC !
Hope this clarifies.
