how to sync with entourage
pemarsh
Jun 5, 2007
93
How do i make iTunes sync with entourage (as advertised that it would be able to).
Under the info tab in iTunes sync, i do not see entourage as an option.
ximermot
Jun 28, 2007
34
you'll have to export your entourage contacts to a text file and import it to address book as a text file then sync with address book.
tdefriez
Jul 2, 2007
139
Don't like the way it works but...
Open Entourage, Preferences, Sync services and check all on. Then Entourage will sync with iCal etc. and then you can sync these with iPhone. The issue I have is the structure of iCal and AddressBooks records - I much prefer Entourage. Check you data as any contact or events notes are not syncronized
