How to take screenshot of locked screen?
seb481
Aug 3, 2007
774
San Diego
I know how to take a screenshot off the springboard or even an opened app but do you guys know how to take a screenshot of the locked screen?
eloi
Sep 17, 2008
19
Southern California
VNC is a remote control type app which allows you to remote control your iPhone from your computer by displaying the iPhone's screen on the computer's screen. "Veency" on Cydia is one. I haven't used it yet.
You'll also need a VNC app on your computer so you can connect. RealVNC has a free edition for Windows. I don't know if anybody has a free one for Mac. RealVNC can be downloaded from http://www.realvnc.com/.
You'll also need to be able to find your iPhone's IP address so you can find it from your computer over Wifi. Install WhatIP from Cydia to do that.
You can do it through SSH. Install "UIkit Tools" from Cydia, reboot, and SSH into the phone as mobile, not root. Lock the phone, press the home button, and type the command "uishoot". The shot will be in your camera roll.
seb481
Aug 3, 2007
774
San Diego
Thanks it looks easier but it's still unclear to me as I am no programmar...
What do you mean by "SSH into the phone as mobile, not root"? Does you mean username "mobile" and password "alpine"? Or do you mean that once inside the phone I should navigate to "mobile"?
type the command "uishoot" - I use WinSCP, is there a way to type a command with this?
Thanks in advance for your help
psylichon
Oct 31, 2007
16,591
751
42
Philly
That's exactly what he means, seb... After getting UIkit Tools, login as mobile/alpine then open the terminal (ctrl-T or from the "commands" menu) and type uishoot once you have your phone with a lit lock screen and it should capture to your camera roll.
I think. Haven't tried it. Nice tip, though linc.
shtofff
Jan 18, 2009
uishoot doesn't work for me on iPhone 3GS iOS 4.0..............
Hi All,
when i'm trying to use the "uishoot" command from the shell i'm getting the following error:
Myiphone-:~ root# uishoot
2010-08-05 14:38:06.672 uishoot[138:107] -[UIImage _imageScaledToSize:interpolationQuality:]: unrecognized selector sent to instance 0x10a570
2010-08-05 14:38:06.693 uishoot[138:107] *** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '-[UIImage _imageScaledToSize:interpolationQuality:]: unrecognized selector sent to instance 0x10a570'
*** Call stack at first throw:
0 CoreFoundation 0x31785fd3 __exceptionPreprocess + 114
1 libobjc.A.dylib 0x320118a5 objc_exception_throw + 24
2 CoreFoundation 0x31789a77 -[NSObject(NSObject) doesNotRecognizeSelector:] + 102
3 CoreFoundation 0x31788f15 ___forwarding___ + 508
4 CoreFoundation 0x3171b680 _CF_forwarding_prep_0 + 48
5 uishoot 0x00002678 main + 1056
6 uishoot 0x0000217c _start + 312
7 uishoot 0x00002018 start + 24
terminate called after throwing an instance of 'NSException'
Abort trap
please advise what am i missing here ?
xenonbluegtr
Aug 2, 2010
67
Naples, FL
wow. you guys are making this waay too difficult...
Now, if I'm not mistaken, you want to take a screenshot of your lockscreen that shows up when you press the home or sleep button correct..? If so, just press the home and sleep button as you would anywhere else on your iPhone. You will hear the camera sound and it will be in your camera roll... You can even take a screenshot of your passcode screen.
fithgear66
Sep 8, 2007
169
+1, I am so confused. Just press the lock and home button!?
