How To Tell Which Cydia Apps are 5.1.1 Compatible?
Arkapigdiesel
Jan 8, 2009
29
Northwest Arkansas
All of my Cydia apps work with 5.0. I'm not going to update to 5.1.1, and then JB to have a lot of my Cydia apps not function properly. I'd prefer to stay with 5.0 until the Cydia apps are updated to work with 5.1.1.
Anyway, is there an online source that will allow me to look at my current Cydia apps to check if they are 5.1.1 compatible? TIA.
Add NCRotationStatusto the list of 'Not Working'. It was the only thing I installed that I had a problem with. It resulted in the phone only being able to boot into Safe Mode.
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Also clearallsms doesn't work. It goes into a never ending reboot until you hard reset.
