how to transfer numbers from Motorola Q
dustoff
Aug 15, 2007
yeah so basically i just need someone to tell me how to transfer my numbers from my motorla Q to my iPhone.
thanks in advance.
sas1
Aug 8, 2007
I don't know if you use outlook, but I had a blackjack before my iPhone and had all my contacts in outlook so when I did my first sync with the iPhone it added all my contacts.
skiz420
Jul 28, 2007
371
Boston
if you have activesync installed and the cable for the q you should be able to just plug it in... pick sync contacts with outlook... let it rip... then hook up the iPhone and sync the contacts from iTunes
Gray
Aug 19, 2007
41
Im not sure if this will work on the iPhone (don't have one YET) but what i have done with past mobile phones is "save contacts to sim card" and then put the sim card in the new one.
just a guess.
