How to transfer songs from iPhone back to PC?
boxta
May 15, 2007
27
My music library with iTunes has always been hosted in my external drive mybook.
and unfortunately .. it just died :mad:
luckily.. i did a back up maybe 9 months ago.. so a bulk of the songs are still intact.. but the new ones are gone..
however.. most of the new songs are on my iPhone.. so i was thinking if i can easily just copy the iPhone's songs back to my PC. so i don't have to find redownload them.
if there's a free software that does the trick.. it would be greatly appreciated
thanks!
Lazarus
Jun 6, 2007
380
Miami
thx I always wanted to do this, didn't know it was possible thx I'm going to check out ipod2pc, will work for iPhone as well right?
watterman
May 27, 2008
I used T-Pot plugin + iTunes music organization...
1) Copy your music folders by T-Pot to PC
2) Add them in Library to iTunes
3) In iTunes preferences make sure you have "Keep iTunes Music folder organizated" checked (This is because, by copying music with T-Pot you will get songs that has name "XXXX" - Where X is some letter from A-Z - and iTunes will rename it by using your music's ID3 tags)
