How to turn off Edge and use it manually
keevill
Jul 30, 2009
21
I have an Edge account with limited hours per month. How can I turn it off and only use it manually when there is not Wifi available and I just need to check email for example ?
shutter13
Jan 8, 2009
2,201
144
Jailbreak, install sbsettings and turn edge off via the edge toggle. Although I have read the edge toggle didin't work with 3.0, not sure if that has been fixed in the last couple of updates or not.Otherwise like the previous poster mentioned, airplane mode, but that will also prevent you from making calls.
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
As shutter stated, jailbreaking will give you more flexibility in disabling different aspects of the iPhone. If not, you can use Airplane Mode and enable Wifi, but you lose the lack of voice calls.
iNinja
Aug 8, 2008
3,984
20
UK
I don't think the sbsettings toggle for edge has been fixed yet, its not working on mine anyway.
keevill
Jul 30, 2009
21
Yeah the phone is jailbroken and I tried using sbsettings toggle but the icon for Edge is not even active, just 3G , wireless and brightness appear to be working.
As a workaround, I just entered incorrect settings in the apn etc fields when I want to disable Edge and then reset the settings if I need to use Edge.
Not ideal but it works.
Jul 22, 2009
20
I have not try this things yet. As I am still using the wifi. But sometimes I get some problem with the wifi like it won't connected automatically and I have to do it manually than. Than I think of using edge. But do not know can I use both systems in my 3G?
keevill
Jul 30, 2009
21
actually I have managed to get sbsettings toggle function to work.
I have not gone into the settings and enabled the Edge button.
psylichon
Oct 31, 2007
16,591
751
40
Philly
When I was jailbroken with SBSettings, the Edge toggle worked fine for me. Only odd thing was that if I had Edge off, 3G wouldn't work. I assumed they were connected somehow at a basic level. But I never thought the Edge toggle to be faulty.
iNinja
Aug 8, 2008
3,984
20
UK
Thats the fault im having. If its not a fault then I apologise for the misinformation, I just presumed.
