How to unlock your jailbroken AT&T phone without restoring
I just unlocked my jailbroken 4S without having to restore. I bought the code from UnlockFusion on eBay last night for $6.75. They sent me an email with a link to send them my IMEI. Five hours later they sent me the confirmation email that my phone was now unlocked and directions for applying the unlock - which included a restore.
I bypassed the restore process and completed the unlock in less than a minute with the SAM jailbreak utility.
1. In Cydia add repo: Binger.com
2. Install SAM
3. Settings > SAM > Utilities > De-Activate iPhone (clear push)
You'll now get a screen saying your phone is deactivated. Keep your AT&T SIM in your phone. Now open iTunes and connect your phone. Make sure you're running the latest version of iTunes. iTunes will reactivate the phone as unlocked and you'll get a message saying the phone is now unlocked.
Verified unlocked with a T-Mobile SIM card:
  • Like
Reactions: Marianne
Napoleon PhoneApart
Jun 19, 2007
33,493
4,417
Upper Marlboro, MD
Confirmed. I just used the SAM method to deactivate/activate my 4S (after purchasing an eBay unlock), and it has a sim that was disabled after my iPhone 5 purchase this morning.
ITS ME DAVID
Jul 8, 2010
1,358
110
L.A C.A
I heard if you have a 4s you can just insert your other carrier sim and it will find service no need for all that other stuff.
No. Mine was locked to AT&T before I unlocked it this morning.
AT&T declined my request to unlock my phone a few weeks ago since it's still under contract, which is why I went with the eBay method.
iphonewarrior
13,847
699
I know SAM (Subscriber Artificial Module for those unaware) was coupled with Redsn0w, it's great to know that it's been packaged up and added to Cydia.
ITS ME DAVID
Jul 8, 2010
1,358
110
L.A C.A
I get that I'm saying once its unlocked and u have a 4s there is no need to restore or do what u did just install others carrier sim and it will detect it.
Hmm. I'm not sure if that works with this eBay method. Everything I've seen says that it needs to be restored unless you use SAM. I've already used SAM, so maybe someone else can test it without using SAM or restoring to see if it works.
ITS ME DAVID
Jul 8, 2010
1,358
110
L.A C.A
If its out of contract and your a current att or previous att customer with the account in good standing you can call att and ask for them to unlock it. If you don't qualify for any of the above then search for username on eBay unlock_fusion and buy the unlock from them Less then $10 and done less then 24hrs.
PinkBanana
Feb 16, 2010
1,476
94
Burnley, UK
Just a shame that UK carriers can't use this service. I have to wait 30 days! Yes 30 days for Orange to provide me with an unlock and it'll cost me £20. Complete and utter rip off in my opinion considering O2 will do it for nothing.
isn't there a way to unlock without purchasing anything ?
They are really cheap (about $3) and far superior to software unlocks since they are permanent and don't require that you stay on old firmware or preserve your baseband every time you update, and they don't require jailbreaking. Additionally, it's doubtful you would be eligible for a software unlock anyway. The last version of the software unlock (ultrasn0w) was released about two years ago, so if a regular iPhone update has been done anytime in the past two years or if the phone is a 4S or 5, it won't work.
bikerboy
Jun 20, 2009
263
Ohio, USA
They are really cheap (about $3) and far superior to software unlocks since they are permanent and don't require that you stay on old firmware or preserve your baseband every time you update and they don't require jailbreaking. Additionally, it's doubtful you would be eligible for a software unlock anyway. The last version of the software unlock (ultrasn0w) was released about two years ago, so if a regular iPhone update has been done anytime in the past two years or if the phone is a 4S or 5, it won't work.
i tried searching eBay , and unfortunately couldn't find where or how to buy this unlock , what should i be searching for ?
bikerboy
Jun 20, 2009
263
Ohio, USA
another issue i am having with a sister's iPhone 3gs is that it needs activation too , how do i do that ? i am no longer in the states so i can't/don't have access to att sim that is active.
