How to unlock your jailbroken AT&T phone without restoring
i tried searching eBay , and unfortunately couldn't find where or how to buy this unlock , what should i be searching for ?
Is yours locked to AT&T? Does your sister's phone need to be unlocked as well?
bikerboy
Jun 20, 2009
263
Ohio, USA
i did go to ebay and purchased the service " thro a different name tho " and they sent me the same steps and said that both 3gs phones that i am trying to unlock are ready
so i went to iTunes coneected the phone , restored and upgraded to 6.1
both phones now are stuck at activation screen and didn't get the phones are unlocked pop up ....
tottaly confused.
tottaly confused.
Do you have SIM cards in these phones?
bikerboy
Jun 20, 2009
263
Ohio, USA
the main problem is i used this method with 4 phones 1 iPhone 5 1 iPhone4s and 2 iPhone3gs
the 5 and 4s did unlock and working fine , the 3gs both got stock on activation screen ....
Okay, so it worked on two of the four. I'm guessing that the two (3GS') that it didn't work on have the iPad baseband. Were these phones unlocked in the past by installing the 6.15.00 baseband and then ultrasn0w? If so, you need to downgrade the baseband before the factory unlock can go through.
bikerboy
Jun 20, 2009
263
Ohio, USA
both devices were restored and upgraded to 6.1 which isn't supported by redsn0w , anyway around that ? thanks Europa
Downgrade them to a lower firmware (you'll need SHSHs to do this) and remove the iPad baseband. You can go back to 6.1 after if you want.
