how to upload NES Roms
Pharaoh
Sep 7, 2007
91
I got the NES application, how can i put roms on it so I can play the games. I know where I can download roms, just don't know where to save them in order for my phone to read them. The message says:
"No NES ROMs were found. Please upload ROMs to /var/root/Media/ROMs/NES"
Conan
Jul 19, 2007
374
Do exactly that.. create a folder called ROMs in the Media directorty..then inside the ROMs..create another folder called NES and put the roms into the NES folder. I used winscp to do this..what program you using?
Pharaoh
Sep 7, 2007
91
the software that put the installer on my phone was apptapp, you mean just put a folder in my media folder for windows? What media folder?
Pharaoh
Sep 7, 2007
91
in my iTunes where it says my iTunes library is saved, i load that folder and it says nothing is in there. i don't know what folder to put the rom folder in. my media folder, that could mean a lot of things. my main media folder isn't where my iTunes files are, and i don't know where my iTunes library is since its not where it says it is in my actual iTunes that i use. help pleasez:(
Conan
Jul 19, 2007
374
do you have winscp installed and running? or iPhone interface
Conan
Jul 19, 2007
374
you are using windows right?
Conan
Jul 19, 2007
374
yessir, windows vista (professional edition, 32bit) to be EXACT
option 1:
Iam assuming you have jailbreaked your phone.
follow the instructions located here: http://hacktheiPhone.com/iPhone_install_ssh_windows.html
that will install the ssh client so you can change the files and such in the phone.
after you have the client installed..
go to this page: http://hacktheiPhone.com/iPhone_install_nintendo_emulator_windows.html
go to step 13 where it starts with logging into the winscp client. once you have logged into it, don't worry about installing the nes.app folder into the phone since you already have it. Just head to the part where it starts talking about roms. its starts at the paragraph: " Now double click the folder" so ctrl+f it for faster transition. follow that and you should be set. once you winscp installed you wont ever have to worry about it again...until
Apple releases an update. Also you can add as many roms as you like. enjoy
option 2:
If you do not want to do that...use ibrickr:
http://cre.ations.net/creation/ibrickr
its very simple. It jailbreaks the phone for you and you can create folders and add files through it.
once you have ibrickr and have jailbreaked your phone..there should be 4 options.. click the "files" option. now you should be on a screen with a iPhone on the side and 2 options upload files and create folder. don't bother with those 2 options yet. look at the iPhone on the right. it should have lots of this listed like "Applications/" "Library/" "system/"... look in that list for the folder called "var/"...its should be in the bottom. click on the folder and you should now be inside it with several other folders... find the folder called "root/" click on that and you should be inside it with 2 folders called "Library/" and "Media/". click on "Media/". Ok now that you are inside the "Media/" folder, this is where the 2 buttons on the left "Upload files" and "create folder" will come in handy. click on "create folder". it will bring up a box which says "Script Prompt: Folder Name", type in "ROMs", EXACTLY HOW I SPELLED IT AND WITH THE CAPITALIZATION AND THE LOWERCASE. hit ok and now you should see on the right in the iPhone that there is a folder called "ROMs". click on that folder and now you should be in it..it will have nothing in it so don't worry about that. click on "Create folder" again and this type make a folder called "NES", again..exactly how I typed it. now the folder should appear on the iPhone on the right. click on the "NES" folder and you should now be in it,again don't worry nothing will be in it. this is where you will be uploading your roms. click on the "Upload files" option and it will allow you to upload now. Just choose whatever roms you want to put in it and you are set. so next time you want to upload roms..just navigate to /var/root/Media/ROMs/NES and upload roms into it. the roms wont work unless you upload them into that exact folder.
don't let the wall of text in the option 2 intimidate you..it is easier then the other one imo lol. GL.
Suud
Feb 18, 2008
NES ROMS- winscp
Hi, I reallllllllllllllllly need help on how to put the roms on my iPhone. im using winscp. after I put in my host name along with root for the username and alpine for the password, port 22, when I login, it says
"network error: connection refused" i don't understand what im doing wrong and if there is something I am sapose to do so the connection is accepted.
PLS help ive been trying to do this for a while lol...
thx :)
velcro123
Feb 16, 2008
CT
Follow these directions to the "T" and you will be able to play NES games on your iPhone/iPod touch
Goodlife08
Jan 23, 2008
53
I've downloaded to my desktop and copied into var/root/media/ROMs/NES
And I still cannot access them in my NES emulator on my phone anyone know how to get them playable?
akophone
Aug 1, 2007
300
An alternative way to transfer the roms is found here.
Worked perfectly for me since I was having problems with SSH.
Good luck!
julia72
Feb 28, 2008
what if im doing this in a mac? how do i do it?
Mar 12, 2008
iphoe
how to upload nes roms oniPhone
vicky
Mar 19, 2008
hi I need help. I tried to jailbreak my iPhone and I used ibrickr. I finished downgrading and then it said something about boot the iPhone so I did and now it just keeps on booting continuously. And the computer doesn't recognize it either.
Please help me
Vicky
