How to Use Both White and Amber LEDs with the Flashlight
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
Thanks to ARX8X on reddit.
So this is how it works:
  • turn on flash (from CC)
  • go to camera app
  • swipe to video
  • turn flash on
  • press home button
You can cover the white LED with a fingertip to confirm that the amber LED is on. I'm still temporarily blinded as I type this.
28,365
5,506
I'm going to wait until someone posts a confirmed way to disable it. I don't down crawl into holes that don't have an exit point.
28,365
5,506
Apparently, there's no easy way (except a restore or possibly resetting all settings) to get it to go back to the normal brightness after you do this. I don't want mine to be blindingly bright all the time.
Kadelic
Jan 4, 2010
4,940
1,646
Dallas, TX
I noticed there were two two LEDs but I never realized only one came on in flashlight mode. I followed the steps in the OP and I can't really tell the difference from before. I can cover the white led and see that the amber one is on.
After testing several times, The amber LED seems brighter when turned on in video mode in the camera app than it does when using flashlight mode.
Then again, maybe I'm seeing things and only think the amber LED is coming on now when I turn on the flashlight. If it makes any difference, I am still using a 5s. Any word if this is particular to the 6/6s? Maybe by this time tomorrow I'll quit seeing spots. :)
28,365
5,506
It's confirmed working on the 5s on 8.4. Try covering the top half of the flash with your finger.
Kadelic
Jan 4, 2010
4,940
1,646
Dallas, TX
Yeah, I saw that in the OP. And like I said, I can cover the white led and see that the amber one is on. I was just unsure if it stayed turned on after toggling it on and off between flashlight and video. After several tests my I wasn't sure I could trust my eyes anymore. O_o :D
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
Yeah. The light receptors on my retinas were spazzing out and trying to head for the hills.
28,365
5,506
Oops, sorry about that. I didn't read your post closely enough.
silvermoon
Jul 17, 2013
1,624
179
Washington
The downsides to using both white and Amber LEDs would be more battery drain and having to disable both lights. The upside is that you would have more light when you need it. I think a better alternative would be to use a stronger/brighter flashlight app like Flashlight or Flashlight XS, and iHandy.
28,365
5,506
Or...buy a flashlight?
You never use the iPhone as a light? I'm surprised I have to state the obvious here, but people use the phone as a light when they don't have a flashlight nearby or because don't want to carry one at all times.
Loquutis
Jun 27, 2010
293
43
Mississauga
Nope! Never have. But one of my hobbies is flashlight collecting. I have around 12 high end li-ion flashlights. The smallest is slightly bigger than a AA battery that can light up my backyard, to a search and rescue one slightly bigger than an aerosol spray paint can, which has a throw of 3/4 of a kilometre.
And yes, one of the smaller ones I carry all the time.
To be honest, I would need to look right now HOW to turn on the phone light.
28,365
5,506
I have severa flashlights, but still end up using the phone as a light more often than I use them. It's usually for quick things when it's more convenient than getting a flashlight. You just pull up Control Center and it's the toggle on the lower left. You don't even need to unlock the phone.
Loquutis
Jun 27, 2010
293
43
Mississauga
I actually had to look to remember how to turn it on, after my post. I found it
