How to use OpenSSH?
CanSpec
Mar 5, 2008
151
Could someone please tell or show me how to use OpenSSH and winscp. I am just new at this and would like to learn how. Thank you for your time!:)
overbo0st2k4
Oct 17, 2007
264
On your iPhone:
Go To Installer and Download OpenSSH.
Connect to your favortie WiFi.
Go into:
Settings > WiFi > Tap the ">" next to the WiFi you are connected to > Note down the IP Address.
On your PC:
Download and install WinSCP.
Open WinSCP
For "Host Name" Enter your iPhone's IP Address that you noted from above.
For "User Name" Enter "root"
For "Password" Enter "alpine"
For "File Protocol" Select "SCP"
Click "Login"
The first time you connect it will take 30-45 seconds, maybe longer.
Then you're connected :)
In case you had any issues, I attached a pic.
CanSpec
Mar 5, 2008
151
On your iPhone:
Go into:
On your PC:
Open WinSCP
Click "Login"
Sorry to bother you again...but I followed your instructions and it gives me a "connection refused" error? Any idea on what that is about? Thanks
CanSpec
Mar 5, 2008
151
Got it working! Thanks! Just a question though...I see that I have an iPhysics folder in my iPhone even tho i removed that app long ago...can I safely delete this folder from my phone using WinSCP? Thanks for your help.:)
Dec 18, 2008
17
Cannot connect using OpenSSH
On your iPhone:
Go into:
On your PC:
Open WinSCP
Click "Login"
I cant seem to connect either. I've installed BSD 2.1 and OpenSSH 4.6p1-2 on firmware 1.1.4 on an iPhone 2G.
Wifi is enabled (since I am successfuly able to use it to connect to my mail accounts, Safari, etc.), and I have the correct IP address.
When I try to connect (using any client - WinSCP, Putty, whatever), it always says "Connection timed out".
Any suggestions?
TIA.
Dec 18, 2008
17
How did you get past the Connection Refused error?
What did you do to get past the "Connection Refused" error?
TIA
hs-devil
Jan 30, 2009
umm..sorry to bother you but i get an error saying that the connection was refused..how to fix this? any help would be really great..thanks
Dec 18, 2008
17
I was unable to connect because I had OpenVPN running on my machine. (It was running as a background service, so I didn't detect it).
I was able to connect as soon as I turned it off.
Kathie63
Mar 15, 2009
414
Wisconsin
I downloaded a theme from cydia but it does not show up under root/library I was told there was a theme folder but there was none.
Can someone give me some advice.
I just got my iPhone 3g 16gb on Friday and jb my iPhone Saturday and installed winterboard.
I found another theme on the internet that I like but I would like to combine the two, using the icons and wallpaper from one and the stationary background from the other.
I am new to the iPhone and still learning. HELP thanks
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
You have to first go to /, then Library/Themes.
Good luck . . .
