Huge battery problem
Heacon
Nov 3, 2011
80
Hey... So I have a huge battery problem... I know the screenshot is bugged so its just the hours you look at. Out of these hours I have used facetime half an hour amd browsed the net for two hours.. Is it normal i already now hit this low? Its my first iPhone and all the tips you gave I am trying... Auto clock off and all the gps things. I only used wifi. Is this a software problem or battery plain bad? It hasn't even lasted 8 hours with yeah low usage. Please help.. And yes i tryed reboots oh and it uses over 25% while I sleep... Sorry for it being danish
Heacon
Nov 3, 2011
80
The thread you linked I already tryed the most of it without luck):
s100tth
Nov 3, 2011
i was under the impression that the iPhone 4s was the same as all others..so the question is how long did you initially charge it for? and do you constantly charge it? i.e. you battery has a memory..so whatever you teach it, it will remember...
verwon
Jul 29, 2011
1,015
121
Seattle
Battery memory doesn't apply to these batteries.
Sent from my iOS ecosystem!
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
No but it can be calibrated. The "10%" may actually be at 20%. Draining it to zero will help reset it back to normal.
I also have heard of doing a reset (home and power button) while fully charged and plugged into a wall socket helps. I have done this and I do think it helps but have heard it has no basis much like the home button calibration debacle a few months ago. (sorry Mindi. I swear it worked for me :) )
verwon
Jul 29, 2011
1,015
121
Seattle
Yes, I had the calibration problem, so did a full drain to fix it.
Heacon
Nov 3, 2011
80
Before this usage I had drained it all the way to dead and let it charge for atleast three hours more then enough
Heacon
Nov 3, 2011
80
Ill try set it in fly mode just to see if I lose less during the night. Good night its at 100% now see if I stay over 80%...
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Your usage is normally. The fact that standby and usage are equal in length indicates that you have an app that is constantly working even when phone is locked/standby. Easiest way to find trouble app is To close the app from the task manager (double click home button from home screen) one at a time till standby increase and usage doesn't. This is a process but will show you culprit app.
Heacon
Nov 3, 2011
80
The hours of my screeny is the amount of hours since last charge so it was only 4-5 hours standby and usage the rest. Anyway tonight while i slept( so no usage at all) and it was in flymode and everything possible was shut off so nothing ran in the background. And It was fresh of the charger.. Loosing 15% while nothing is on is way to much.. So what did eat my battery? Auto change clock is also off... Any ideas?
