Hybrid Headphones
jensph
Sep 22, 2007
What headphones exist for the iPhone that play stereo audio and control the phone?
I can find only two:
1) the headphones that come packaged with the iPhone
2) Seidio 2-IN-1 Stereo Isolator Earbud
http://store.everythingiPhone.com/content/accessories/73-74--2926.htm
My ears were not designed for earbuds (they just fall out), but maybe the Seidio's have enough pressure to stay in. Do I have any other options?
I have some Jabra's I used with my last phone, but their (4 conductor) 2.5 mm pin will unfortunately not fit.
jensph
Sep 22, 2007
Digging a little deeper in this forum uncovered a number of posts on this topic.
To summarize, besides the Apple set, it appears these are the options:
http://www.rivetnow.com/home/file/category/icategory_id/40/iPhone_Headset.html
http://www.seidioonline.com/index.asp?PageAction=VIEWPROD&ProdID=804
http://www.ultimatebuds.com/etymotic.php
http://www.shure.com/PersonalAudio/Products/Earphones/att/index.htm
http://www.v-moda.com/collection/modaphones/vibe duo.aspx
The first two are less than $40, while the last three are at least $100.
Houdini07
Sep 25, 2007
Do you have any info on which are most recommended? Would be really helpful, thanks.
jensph
Sep 22, 2007
My impression from others' posts is that the Rivet is a good value: they're relatively cheap, functional, though you won't get the best audio quality. On the other hand I've seen only good things about UltimateBuds' quality - though their price is out of my range for a wired headset. With the current version of the V-Moda there's apparently an issue with the clicker to take a call. I haven't seen much about the Shure or Seidio.
I'll probably go with the Rivet as a hold-over until a Bluetooth equivalent is compatible (assuming Apple updates the iPhone to support A2DP).
