I can't open iTunes anymore - PLEASE HELP ME!
Terry M.
Feb 27, 2009
728
84
45
Des Moines, Iowa
I was moving a few things around on my drives today and somehow I did something not very smart and now I can't open iTunes anymore. When I click on the shortcut it gives me the error message: "the folder iTunes cannot be found or created and is required. The default location for this folder is inside the 'my music' folder.
That's all I get. I tried moving everything back the way it was but failed apparently because everything I've done has resulted in the same error message. :mad:
I even went to iTunes.com and downloaded it again in hopes that I could sync my phone up and it would restore everything. No dice. I click on the new shortcut and I get the same darn message!
Can someone PLEASE, PLEASE help me?
Thanks!
1,745
52
Long Island N.Y.
Did you try a system restore? That might help...but reinstalling iTunes should have fixed the problem, unless there is something else wrong...not sure.
Terry M.
Feb 27, 2009
728
84
45
Des Moines, Iowa
Thanks for your advice. I figured it out late last night. Did all kind of searching on the net and came up with this page which took care of it for me.
