i cant play movies no more! help
meschee
Feb 25, 2008
hi all
up until recently i have been able to download and watch movies on my ipod.....now they wont register at all and iTunes says i have no rented movies on my ipod!
why has it changed!
iStealth
Nov 5, 2007
421
hi all
why has it changed!
Just rented movies or others that you own? did you start watching them and stop? if so they may have auto deleted, cause after you start watching you only have 24 hours to watch. Just my guess..
meschee
Feb 25, 2008
no these are rented movies these are films ive had on my iopd for ages! they are in my iTunes bit wont go into ipod!
fury
Oct 23, 2007
2,274
238
33
Louisville, KY
Are they showing up in your iTunes library, and do you have checkboxes next to the movies, as well as next to the appropriate setting in the sync configuration?
fury
Oct 23, 2007
2,274
238
33
Louisville, KY
Can you show a screenshot of the sync settings for the Videos tab? On mine, when my iPhone is connected, the rented videos section shows up at the top, (of which I have none) then there are TV shows, and at the bottom is the option for me to sync selected movies. I manually added all those movies to my iTunes library, but I have to check them both in the iTunes library list AND in the sync screen for which movies to sync to the phone.
betty0920
Mar 27, 2008
You can download and convert some online movies and synch them to your itune. Maybe it's better.
You can search "flv to video converter" on google.com for more info.
Hopefully it's helpful.
