I Can't Sync My iPhone To My Computer Anymore?
Pimpboy51
Sep 18, 2007
456
25
Orlando, Florida
Ok well, my computer got a bolt of lightning fry it. It still works, but a lot of my programs aren't working well. My biggest issue right now is that I can't sync my iPhone 3G anymore! It thinks it's on someone else's computer!? Yet when I back it up it backs up real fast so the 3G backup is still there. I can't add anymore stuff to my iPhone because it's locked on iTunes. What should I do? Is There A Way To Let Me Add Stuff Again? :(:(:(
15,385
1,089
did you get signed out of your iTunes account?
5,578
I don't understand what you mean. Is iTunes recognizing it? Can you post the errors you're getting?
Pimpboy51
Sep 18, 2007
456
25
Orlando, Florida
yes it shows up on iTunes, all info is there.
but when you click the music tab under my iPhone's name,
all the music is transparent. non clickable at all.
I can't add music at all. There are no errors, just I can't add music.
It's like if you take your iPhone to your friend's house and you can't play or add music to your iPhone. And if I do try to add something it says this iPhone is synced to another computer. And it asks me to erase and resync but I can't do that since there is audio files on iTalk I can't tranfer over to my pc because I don't have wifi in my room.
