I feel dumb for asking but..
cfrau15
Aug 23, 2007
I'm very new to the iPhone scene, and i just down loaded a jailbreak software and it tells me to put my iPhone in recovery mode by holding the home and the sleep/wake button for about 25 seconds. But when I do this my iPhone just shuts off. im sorry but I really need help.
Kipper
U have to hold these 2 buttons down until it says "connect to iTunes" with a yellow triangle around those words then let go and let the prg do the rest. U can test it to see if it worked if u launch interface and it says established. Lots to read and learn if u want to properly mod the phone. I would advise searching this forum as well as hacktheiPhone.com for more information. If u are not comfortable with your way around the computer I would hold off modding the iPhone.
cfrau15
Aug 23, 2007
thanks
i feel comfortable enough but the triangle and the "connect to iTunes" never shows up the phone just shuts off
skiz420
Jul 28, 2007
371
Boston
http://cre.ations.net/creation/ibrickr
tri ibrickr if your new... it helps with the jailbreak... but you still need to hold the power/sleep button on the top and the home button till you see the triangle.... just keep holding them the triangle will come up after the Apple logo.. it takes a lil while tho
cfrau15
Aug 23, 2007
I'm actually on a mac
And it looked like that was for windows but thanks I'm actually using iActivation to jailbreak does any one know about this software
Tinman
4,334
183
Aridzona
Make sure you have the iPhone in the cradle, or attached to the computer via a sync cable, when you hold down the buttons--and hold them down till the triangle appears.
Also, try using Breezy, if you are on a Mac:
http://code.google.com/p/pxl/
Mike
