I GET ERRORs WHEN SYNCING MY iPhone!
gotnagel
Jul 6, 2007
40
MANY ERRORS! CHECK 6 of the photos!
Does anyone know how to fix this? I get these errors when i first plug my iPhone onto its dock.. seems like there's a problem syncing..
is it my computer or the iPhone that is causing the problem?
justahsquirrel
Jun 7, 2007
545
Queens, NY
well it seems that you have some issues there fella. You may have too many backgroud apps running. Try msconfig and turn off unnessessary backgroud apps. Restart. Uninstall iTunes and QuickTime. Restart. Install iTunes+QuickTime.
gotnagel
Jul 6, 2007
40
i've tried that.. with combinations of different configs set ups..
any other ideas? i really do not want to format my computer..
Hopefully that works if i do, though.
