I hate iOS 7!
Dec 21, 2013
11
Does anyone else wish they could downgrade to ios 6? I have always been a Apple fan but the new ios look makes me want to switch to a Droid. Does anyone know when Apple may release another update for ios 7?
Sent using iCafe app
28,422
5,548
What don't you like about it besides the look? 7.1 will be released soon, but it doesn't change the look. This design is here to stay for a while. I got over what I didn't like about the look a long time ago. I care about functionality and iOS has more features than iOS so I don't want to go back. It still has a couple bugs that need to be worked out, but other than that I'm happy with it.
Dec 21, 2013
11
I like the functionality but the translucent look I can't stand. The battery life has dropped dramatically as well despite turning off some things and adjusting the screen brightness.
28,422
5,548
The battery life should be about the same. You might want to restore if it's consistently dramatically decreased.
Ledsteplin
Oct 29, 2013
4,841
997
65
Florence, AL
I wasn't thrilled with the new look either. Too much white with thin gray lines. I prefer textures and shadows. But I've gotten used to it some. I do like most of the new features. That's made the update worthwhile for me.
Nrevezzo
Apr 15, 2009
104
23
Canton, Mi
I'm waiting for the jailbreak. I'm sure one of the themes will be the iOS6 look.
denzel1989
Oct 12, 2013
125
21
I kinda like iOS 7. It's more vibrant and stands out better.
Jun 19, 2007
33,486
4,549
Upper Marlboro, MD
I hate the lag between some actions with a passion. What ticks me off is that this isn't lag caused by a bad balance between hardware and software but an intentional lag.
iPutz
Nov 20, 2012
962
184
43
72
US Midwest
If battery life is your main issue, you might want to try Europa's tip and restore the phone. I have always installed each new version of iOS as it came out onto my iPhone 5 and my battery life seems to have gotten slightly better with the iOS 7 versions.
Dec 21, 2013
11
Also my iTunes is messed up since the new update. My album artwork has become mixed up with the wrong albums. To my knowledge I have tried everything to fix it besides doing a hard restore. I want ios 6 back!
Sent using my iPhone 5
MrMike6by9
Nov 16, 2008
1,482
121
70
Maryland, USA
I just read on Reddit someone's complaint regarding OS 7 on the 4. A responder suggested turning on "reduce motion" and "increase contrast" in accessibility. I just made those changes on my iPad 2 and my 4s and it does seem to respond more smoothly and looks "better" particularly on the iPad. Time will tell.
YMMV
28,422
5,548
YMMV
I just tested "Increase Contrast" and it does disable the translucency.
@wreckedveteran, you can enable it here: Settings > General > Accessibility > Increase Contrast
