I have a PC and want Installed apps.. HOW?
DMcGrew
May 30, 2007
282
So I've been seeing all this talk about all these new apps. I guess I need Installer.app to be able to get these apps on my iPhone, right? Well it looks like Installer.app is only for Macs. So, am I screwed?
Aug 9, 2007
178
you need iBrickr
it's the windows app that will jailbreak your phone and allow you to install the rest
DMcGrew
May 30, 2007
282
Thanks. So do I need jailbreak first? Or do I just basically need App Tap and I'm ready to roll?
Giies
Jul 31, 2007
55
use ibrickr, it's the best, visit ibricks.com for video tutor how to jailbreak your phone and install all apps.
katra
Jun 26, 2007
229
dude, use ibrickr ! it is the bomb!:laugh2:
i have windows, so i know....
it's so easy to use and it does it all for you...it even has a video tutorial on how to...
i love it....don't use anything else.....give it a try !:laugh2:
venturo
Sep 9, 2007
30
apptap is easier to get started, then i would get ibrickr. with apptap all you need to do is d/l unzip and run the exe with yur iPhone plugged in. Then you can go from there.
Flyinb
Jul 9, 2007
23
www.400N.com
Dude just go to ModmyiPhone.com go to wiki on left side select apptapp for ws download and run exe, nothing else to do don't even have to jailbreak
Aug 9, 2007
178
Huh?
i don't see wiki on this page, nor can I find any apptap for windows?:mad:
venturo
Sep 9, 2007
30
Download this
http://rapidshare.com/files/55269765...pInstaller.exe
double click file
follow directions
close iTunes and plug in iPhone
This will jailbreak your phone for further modding, the installe comes with a variety of things to add, pretty much a one stop shop, after this you can get ibrickr and start to mod files like yur png and caf files. once the installer is done, you will end up with a icon labeld installer, when you go in it there will be a ton of things.
blurm
Sep 9, 2007
46
Can't install iBrickr, I have a unique problem
I cannot use iBrickr BC it won't install PXL Daemon bc the power button on the top of the phone is broken. I have wanted to open the thing and fix it but fear bricking it. I can't use WinSCP bc the iPhone can't register on the network, I am to far away from the router. OK i am cheap and am using a cantennae lol, screw the man! Any suggestions installing using dos or something, I am not familiar with programming but I used the hex editor to bypass activation and jailbreaked. (I have been modding the skin and icons etc.) I just wanted to give you an idea of the speed I am at. That's where I am.
